3VZE/Auto Bellhousing Bolt
What size are the bellhousing bolts in a 3VZE block? I think 10x1.25x?Long but that's just based on my machinists handbook and the 17mm head size, I would prefer to confirm before I head home with the wrong bolts.
I need them to put my new motor on a stand and didnt think to pull one out of the truck to bring with me to work today. Thanks Josh |
FYI: they were M12 x 1.25 threads. I had to use 80mm long bolts.
(PS: going from the head size to bolt size works occasionally, but is not very reliable. For instance, the 3VZE has lots of M8 nuts with a 12mm head, but if you buy one at the hardware store it is most likely to have a 13mm head. More meat is good, but occasionally the nut sits in a space too tight to get in the larger socket.)
