3VZ overheating
89 truck. New toyota radiator and t-stat. truck will idle all day long at normal temp. Takes about twenty min to start creeping up in temp when driving. engine is new to the truck. checked head gaskets and we have nothing sticking out the passenger side. stumped???? open to ideas. This is a friends truck that i am trying to help him figure out. thanks Kevin
A list if things to check, fan clutch, radiator shroud, water pump may not circulate, clogged passages in engine or hoses. How hot does it get?
A list if things to check, fan clutch, radiator shroud, water pump may not circulate, clogged passages in engine or hoses. How hot does it get? A lean running engine also can overheat.
Originally Posted by sechott
(Post 51830467)
Did you burp the coolant system and add coolant? Are you sure you got all the air out of the system?
Originally Posted by 93toyrunner2
(Post 51830480)
Park the truck with the front up hill & fill while the engine is running, allowing the system to burp itself. That's the only way to ensure you get all the air out.
