3.0 injector style?
I just got off the phone with Summit racing and they said if the 3.0 has a bosch style injector that they have some Accell injectors for $38 ea.Does anybody know what style we have?
http://store.summitracing.com/defaul...=egnsearch.asp |
Top feed Denso. 1.7ohm, 200cc @ 41.24psi
Stock FPR is 37psi @ WOT, 41psi no vacuum (Disconnected). |
What would be the next step up for the 3vze? And what car would you get it out of?
I think the 3.4L swap out of a 96 model and up is the common upgrade. Engine code is 5vzfe.
Mike in AR |
I'm refering to the next injector size not engine.
A short list of old Toyota injectors.
http://www.geocities.com/MotorCity/P...Injectors.html Mazda used many, many sizes larger than Toyota. Old turbo probes used 315cc injectors, while RX-7's came with 470-550cc secondary injectors. |
So what would be the next best step up that will fit?
Any top feed Denso injector until the last few years is going to "fit".
What you have is good for 216bhp if you unhook the FPR from vacuum. With a $30 FPR off ebay you can bump it to 60psi @ be good for 260bhp. (N/A, under boost you wanna drop that another 10%) |
