2TR 4Runner 94 swap
Hi.
Recently this year bought a 94 4Runner, with a rebuild 3VZ, i knew it was going to be a matter of time to change that engine, it came rather early than expected. Anyway, while looking for a 5VZ found a 2TR-FE with a manual transmision for about $275 bucks. So, it begins. My plan is the following: -Check for any obvious damage, clean it, etc -If the engine is viable, buy a complete timing kit -buy ECU -see what else comes up. I would greatly appreciate any help on this attempt of a swap. Regards.It has a nick on the block a a broken bracket https://cimg7.ibsrv.net/gimg/www.yot...1c5c3b728d.jpgFan clutch is gone. https://cimg8.ibsrv.net/gimg/www.yot...0e380eb7b7.jpg https://cimg9.ibsrv.net/gimg/www.yot...3942261e48.jpg https://cimg0.ibsrv.net/gimg/www.yot...f1b1263f08.jpgCloser look at the fab clutchx https://cimg1.ibsrv.net/gimg/www.yot...9d0b6e8a2d.jpgYeah, I need to buy the 4 coils. https://cimg3.ibsrv.net/gimg/www.yot...d9b35d282a.jpg https://cimg5.ibsrv.net/gimg/www.yot...f896656e6c.jpg https://cimg5.ibsrv.net/gimg/www.yot...6c819c1117.jpg https://cimg9.ibsrv.net/gimg/www.yot...f69cdc4a01.jpg https://cimg0.ibsrv.net/gimg/www.yot...ea0f890484.jpg |
Best of Luck !!
I guess you have your reasons . Should be very interesting |
Sweet!!!! That bell housing should allow you to bolt up a W56 series transmission. You will have a couple option for motor mounting. If my research was correct it mounts same as the 3RZ so you can buy bolt in mounts or cut, trim, and reeled your current mounts/brackets. I think wiring will be your biggest challenge will be wiring. I haven’t seen any PNP harnesses but maybe ORD or toysolutions can help. Of course you can get wiring harnesses from donor vehicle and FSMs for both years and make your own. I’m really interested in this swap so please post progress... thanks!!
Originally Posted by muddpigg
(Post 52380880)
UPDATE.https://cimg9.ibsrv.net/gimg/www.yot...97d2bd35c2.jpgFan clutch is busted. I think the donor vehicle was involved in a rollover or some accident.
https://cimg4.ibsrv.net/gimg/www.yot...11ac92c2a4.jpgYup, lot of rust. Had to come to a halt trying to separate the engine from the transmission. Some bolts are really rusted, they are being soaked in a penetrating solution. https://cimg6.ibsrv.net/gimg/www.yot...96548e14bd.jpgYup, engine is stuck. It doesn't turn. https://cimg8.ibsrv.net/gimg/www.yot...3c928f9258.jpgIt's as bad as it looks? 2 or 3 lobules from that cam have light rust. Hope it doesn't affect the function. https://cimg0.ibsrv.net/gimg/www.yot...d56423fbb1.jpgOn the other hand, chain and sprockets look clean. https://cimg2.ibsrv.net/gimg/www.yot...7677f6756c.jpgPlastic cover has a hole, i'm thinking that some engineering with plastic or metal, jb weld and 4 screws with pressure washers and nut would do the job. https://cimg6.ibsrv.net/gimg/www.yot...19d84adc73.jpgAlmost striped and a whole more to come. After separating the engine from the transmission, a quick trip to the shop will tell us the damage. |
Don’t think the manual tranny from the 3.0 will bolt up but the 22re tranny will using bell housing from 3tr. Also let’s you run gear driven transfer case instead of chain driven. I’m not sure if 3.0 motor mounts are in same location as 22re knowing Toyota they probably are.
(Post 52380916)
3VZE and 22RE have use the same manual transmission. I'm sticking with the manual transmission that is attached to the engine. I'll look further into making it 4x4, maybe i'll start with a simple IFS setup. Thanks for your input. |
Originally Posted by fuel383
(Post 52380963)
O.o 22re????
3VZE and 22RE have use the same manual transmission. I'm sticking with the manual transmission that is attached to the engine. I'll look further into making it 4x4, maybe i'll start with a simple IFS setup. Thanks for your input. ooh brain fart, I assumed you were 4wd if your 2wd not a big deal use tranny that came with motor. |
https://cimg8.ibsrv.net/gimg/www.yot...6dffc5d2a.jpegTaking apart the 2TR, gunna need a good clean.
https://cimg9.ibsrv.net/gimg/www.yot...10c46004c.jpegsome minor repairs, new gaskets and bronze plugs. https://cimg0.ibsrv.net/gimg/www.yot...5156efdd8.jpeg2TR transmission bell with R150 transmission, what do you know? They actually fit! https://cimg1.ibsrv.net/gimg/www.yot...921ca6bff.jpegGood ol' cleanin' to transmission too. https://cimg2.ibsrv.net/gimg/www.yot...7755dd2e2.jpegNew gasket here. |
If anyone has done this swap, any advice regarding the engine mounts would be of great help.
Hey man. I'll attach a link to my thread that may cover a little of the information your missing. Prob should've posted it under a more general thread to get some more exposure, but whatever. Hopefully you're still trying to tackle it. It's awesome to drive!!
https://www.yotatech.com/forums/f161/completed-2tr-fe-87-22re-4runner-306336/ |
