2nd Gen Winch Mount
Just wondering how people have mounted winches without spending alot of $$$$$$$$$ I have a stock bumper with the pro comp prorunner bar and was thinking of maybe taking the bumper off and tying into the frame some how anyone done anything like this?
If you mean trying to make the procomp bumper capable of supporting a winch that is not going to happen. You need more beef on a bumper than that puny light holder to mount a winch.
Maybe something like this. No you can't convert your light bar to a winch mount.
http://irbisoffroad.com/img/winchcradle1%20(Custom).JPG |
is that a landcruiser??
1 Attachment(s)
here's mine, the bumper is from Daves Offroad he used the trailgear winch plate.
Attachment 182272[/IMG] |
The TG winchplate alone would be stronger than the pro-comp lightbar.
Originally Posted by titus
(Post 50996884)
Thanks, they're also pluged in through the wheel well ;)
1 Attachment(s)
her is mine using a universal winch mounting plate bolted to the crossmember and then reenforced with some steel strap welded to the winch plate and bolted to the frame underneath.
this is my solution until i can get a new bumper with integrated winch plate. Attachment 182273 |
I didnt want to make the light bar the mount but maybe tie into it I think im going to just get the TG winch mount nice and simple
www.addictedoffroad.com
is having a crazy sale right now 325 for winch bumper no stinger check it out he is a great guy! http://addictedoffroad.com/myPictures/sscn0028.jpg |
Originally Posted by dotcom
(Post 50997021)
this is my solution until i can get a new bumper with integrated winch plate. http://i44.photobucket.com/albums/f2...g/photo-53.jpg |
I made a receiver mount so I could move my wench cradle or other accessories to be in the front or rear. I know it's overkill but it's attatched at all 10 locations in the frame. I also added a tranny cooler because this blocks the lower tank of the radiator where the stock cooler is. I normally just keep a tow link in it, except for when I go wheelin. Last pic shows with my bumpers powder coated hammertone black and cleared.
http://www.jamesdeancreations.com/4R...20Straight.jpg http://www.jamesdeancreations.com/4R...e%20Driver.jpg http://www.jamesdeancreations.com/4R...20Bolt%20w.jpg http://www.jamesdeancreations.com/4R...olding%203.jpg |
Originally Posted by bigt
(Post 50998276)
Originally Posted by James Dean
(Post 50998722)
that thing is sweet trailgear sells something similar check it out http://www.trail-gear.com/toy-bumper.html has the winch mount and reicever
Originally Posted by Cyberman
(Post 50998714)
That seems like a simple enough solution. What are those blocks above the mount for (bolted to the bumper)?
2 Attachment(s)
This is what I built using the JAMES DEAN DESIGN maybe a bit of over kill it's made of cold rolled 1/4 plate steel hoping to have to replace the truck before the bumper lol.
The roller and hitch are off center a bit to center the winch cable to the middle. Attachment 182274 I also got a couple spring clips I guess is what you call them to mount on the fairlead rollers and the licence plate covers the fairlead rollers. Attachment 182275 |
sorry for posting on an old thread but im trying to mount my winch to the front of my 91 4runner and i was doing some research and found this post. on the picture you posted you circled the bolts with yellow did you use the holes that were already tapped into the front bumper reinforcement? if so what size bolts did you use? thanks for any help
posted in your other thread
