22re starting sound? Won’t start
#43
Here's the timing cover. It looks like a piston too, I don't know at this point. I was planning on getting a rebuilt motor, which would be exchanging my block for a refurb w/new head. Now it just keeps adding up. Haven't even taken the head off.
#44
Yes. You saw the piston come to the top of the stroke, but which stroke? Compression, or exhaust? Just to be clear, the crankcase doesn't know and doesn't care which up-stroke is which. That is determined by the cam -- the valves are closed on the compression stroke, and the exhaust valve is open during the exhaust stroke. That's why looking at the valves is the "fool proof" (or at least most reliable) method.
But you have to remove the timing cover to do that. If you're not sure you're doing the finger-on-plug-hole method correctly (I don't find it very easy), you pretty much have to remove the timing cover to tell.
Leigh Rathner
02-20-2017 08:09 PM
rewind206
06-15-2014 02:31 PM
dpross16
04-27-2011 06:04 AM
Schump
03-02-2009 10:18 AM
