YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   22re ran out of oil (https://www.yotatech.com/forums/f116/22re-ran-out-oil-201108/)
dwnhiller93 01-10-2010 04:13 PM
22re ran out of oil
I woke up for church and went out to start my truck. I went back in, came back out 5 mins later and the motor wasn't running.. I was like oh..crap.
Anyways, checked the dipstick, no oil. And no, the oil light never came on the day earlier when I was driving it. But my question is, when it ran out of oil, the RPM's were only at like 600-700, and it wasn't actually driving. So maybe I have a chance of freeing it up somehow? My dad said no way.. But maybe if stuff inside didn't bind up all the way or bend or something, maybe it has a chance?
StangBanger 01-10-2010 04:20 PM
Same happened to a 2000 isuzu rodeo v6 that used to be my wifes and now i gave it to my lil cousin. I drained the tiny bit of oil in it and dropped some mobile1 5/30 into it with a lil lucas started her up for like 3 seconds and the engine shook violently so i turned it off quick. Its trashed right?
peow130 01-10-2010 04:29 PM
Well, when theres no oil lubing up the cylinders, the cylinder walls get gouged...
i would take it apart, and at the very least take off the head to inspect the cylinder walls.
1990yota-pickup 01-10-2010 04:31 PM
sounds like some little bastard drained your oil in the middle of the night..
peow130 01-10-2010 04:48 PM
That too.
I would check for foul play on the oil pan.
Blk63vette 01-10-2010 05:18 PM
Originally Posted by peow130 (Post 51330293)
That too.
:bang:
I hate to say it but Sounds like it to me..
shaeff 01-10-2010 06:23 PM
First thing to go is generally the rod bearings, main bearings, after that- the motor will seize due to no lubrication on the cylinder walls. That's if it doesn't spit a rod through the side of the block first.
Junkers88 01-10-2010 06:56 PM
My first thought is someone drained it. Find them and kill them.
Ok as far as trying to save it goes I'd say fill it with the oil of your choice along with some Lucas oil treatment. Pull the spark plugs and using a spray bottle shoot some oil into the holes, turn the engine by hand a few times and keep lubing the cylinders with the spray bottle. Then crank it a few times without the plugs in it. Put the plugs back in, fire it up (don't worry about all the smoke since that is all the oil you sprayed in the holes burning off) and let it idle to operating temp. You'll have to change the plugs probably but if it runs and stops smoking then a few bucks for plugs is a good investment.
Teuf 01-10-2010 07:00 PM
BRB i am going out to ✔ my oil. ☢✙
Junkers88 01-10-2010 07:13 PM
Me too. Now I'm nervous about some punk pulling the plug while his friend steals my cat.
Teuf 01-10-2010 08:20 PM
MMMM i think i'll wrap my Pal around my cat for insurance......
http://i561.photobucket.com/albums/s.../snakehold.jpg
874runnersr5 01-10-2010 08:24 PM
Ive always wondered if any butt muncher will drain your oil over night.. i cant believe someone actually would.
dwnhiller93 01-10-2010 08:32 PM
Yeah.. me and my dad both think someone drained out the oil... I am not very happy right now. I will try a couple things after school. With my luck, doubt it will work.
Matt90V6SR5 01-10-2010 08:33 PM
Did anyone stop to think maybe he hasnt checked it and just ran it dry? Ive accidently run an engine low before but not dry.It happens
dwnhiller93 01-10-2010 08:35 PM
I checked it around 2 weeks ago. It was fine.
bend 01-10-2010 08:41 PM
Just because there is no oil on the dipstick doesn't mean there isn't any in the engine. It is just a quart or more low.
Teuf 01-10-2010 08:45 PM
May need Perry Mason on this one.
Matt90V6SR5 01-10-2010 08:55 PM
Lol yeah,maybe,have u looked for evidence of vandalism? have u pulled drain plug to see if there is any oil left? I would be under it in detective mode.
Marc 01-11-2010 07:39 AM
If someone drained it, wouldn't there be a big puddle of oil underneath?
Is the drain plug in. I doubt if anyone would put it back in.
As others have said a) they do run out of oil sometimes b) might be 1 quart low.
xxxtreme22r 01-11-2010 09:04 AM
If you can't turn the crank with a wrench, then I would definately say the crank, #4 bearing and most likely #3 bearings are at the very least toast. Cyl walls should be fine. Mine were in my rebuild when I seized the crank twice becaus of no oil pressure. (missing oil galley plug on the front) If engine is seized (ie cannot turn by hand) Your gonna have to drop the pan to check it out. Mine ran for about 5 minutes at about 3500-4000 RPM without oil pressure the first time.
