YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   22re Engine trouble (https://www.yotatech.com/forums/f116/22re-engine-trouble-97429/)
cweich Oct 18, 2006 09:00 AM
22re Engine trouble
I have a 1985 22re that has a knock in it, i thought at first it had an exhaust leak, but the further i tear into the engine the more i fear its the bottom end. I this common in this engine to have bottom end trouble? Any suggestion from anyone.
Thanks
dougm395 Oct 18, 2006 12:16 PM
mine had a knock. upon rebuild i found out it was the piston hitting the cylinder head.
4Hummer Oct 18, 2006 12:21 PM
Call ted and Engine builder and Rebuild it.
Bottom bearing went on my 22RE after 600,000 KMS
if you have a SFA you can replace the bearings by just removing the oil pan. If IFS Pull the motor
the 22RE is a very simple engine to work on.
dcg9381 Oct 18, 2006 02:09 PM
Thanks
Common? No. Bottom ends are typcially good for some very high mileage.
Wear happens though...
