YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   22re block HELP!!!!! (https://www.yotatech.com/forums/f116/22re-block-help-133027/)
92toypunk Dec 22, 2007 09:38 PM
Ok... i need help bad. I went to put new headers on, and the last bolt(top) in the very rear is cross threaded in the block. It sits flush and fine... except where that bolt is... Now i have an exhaust leak... and i need to fix this.. im 17 and dont have many tools... how can i... or what should i do to correct this. :con: any help... thanks
92toypunk Dec 22, 2007 09:39 PM
and what really bums me out... i just got my flow master on and it sound bad a** just wish i didnt have the leak up front...
SoCal4Running Dec 22, 2007 09:49 PM
Go to napa and tell them you need a Heilicoil. They'll point you in the right direction.
Kaydon Dec 23, 2007 07:49 AM
X2.
Seems that one always gets FUBAR.
Georgiadave Dec 23, 2007 05:53 PM
1:38 AM? Wow. On my 94, the exaust manifold has studs and nuts, not bolts. Does your header attach with bolts? If studs, is the stud cross threaded into the block or is the nut cross threaded? If it is the nut, you can replace it. If the nut end of the stud, you can replace the stud, though you may have to remove the header and or use a pipe wrench to get the stud off.
Flash319 Dec 26, 2007 05:18 PM
Try putting in a longer bolt. I have had this problem with the same hole on two trucks now. I just put a longer bolt in as the threads are still good deep in the hole. I have also put in a different thread (course) bolt and took it easy. It is an Aluminum head so it is easy to strip but also easy to cut new threads with a bolt:D .
black diamond Dec 26, 2007 06:21 PM
ooof!!!! i wouldn't do that!! sorry, N?G
black diamond Dec 26, 2007 06:23 PM
get the right size tap, and be careful and patient!!!
flatbedyota Dec 27, 2007 05:59 AM
i would try the longer bolt first..easier and cheaper.....if not you can put a helicoil in, a little more expensive and time consuming but it would be the best way to fix this problem for good
thook Dec 27, 2007 07:16 AM
Why not? And what is "N?G" ?
