1994 Pickup FSM manual
I need to get the FSM for my truck, just wondering if anyone already has downloaded the full manual and could email it to me in pdf format or whatever.
Since the body/design didn't change til 1995.5, the 1993 FSM should be of some help.
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Originally Posted by snap-on
IF you use firefox it has an extension called "down them all" which will download all the "links" on a page good for grabbing all those PDF's
Is this a link I need to dl or do I already have it?
FireFox extension
You have to download it.
To download use the Firefox menu bar Tools, Extensions. It will take you to the website. Find the DownThemAll! extension and download it. Once downloaded close and restart Firefox. The file will install automatically after the restart.
94 toyo 22re failed nox......lloks like this is normal for an older 22re EGR......throttle body clean, new EGR vsv valve(toyota part#90910-12086), hoses, modulator,, TPS, new vsv plugin connectors and more....not burning oil or leaking....runs ok. 1.....possibly not enough vacuum from the TB (or) the computer is not able to communicate with the vsv to open the vacuum to the egr and modulator.....i tested all the vsv's....they work......no vacuum to the egr and modulator......this model has 4 vacuum ports on the TB....the front port goes to the vsv on the valve cover then to the EGR and modulator in the back.....the vacuum out the TB port is not very strong......is this normal for this port?.... looked in my cheap manual line search for egr wiring diagrams......nothing..... all i found was vacuum hose diagrams.....2....other than the vsv's are there any solonoids, fuseable links in the wiring circuit i missed that could stop the electric current to open the vsv and create the vacuum to the egr and modulator......it has new vsv plugins..... 2....can you post or email a 1994 toyo 22re egr wiring diagram to look for any of the above components in the egr wiring?.....could not find any wiring diagrams....i dunno why the egr dont work..... 4....any ideas? thanks......
Road Bull
10-10-2015 04:55 PM
