1992 toyota pickup 3vze auto tranny Air Flow Meter Problems
truck wont shift into 2nd untill its warm could the AFM cause this? btw when it tries to shift into 2nd it just dies any info would be helpful;thankyou
No.
You know, that transmission will diagnose itself. http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf |
thank you man i replaced the AFM anyway and changed nothing im not sure theres a problem with the transmission because usually after you drive it, it will straighten itself out i will try that method thankyou.. any more info would be highly appreciated as i need to get this fixed..... once again thanks
