1991 3.0 Head gasket Repair advice
#81
.....and the you're gonna share it with the rest of us.
big fat fail on getting those bolts off.....bent the pulley holder tool.....i'm brutal to these tools. used the electric impact wrench i just got today, no dice.
gotta get a new pulley holder now.
#82
Ah damn! Sorry to hear that! And I will most certainly be posting how and what Im doing. I need you guys to tell me Im doing it wrong before its too late!
#84
OK.....got them off....tried several methods but ended up just wedging against the middle pulley thingy with the coolant passage in it.
BTW...here's a good read----->>>>> https://www.yotatech.com/forums/f116...vations-32812/
#86
So bad news on helping you guys with the head clean up.. I dropped the heads off at a local shop to have them inspected, machined if needed, and cleaned up. I'll take some pics when I get them back. Havent had any time to look into where Im going to order my gaskets yet.
On another topic, what all should I consider replacing? My list so far:
Head Gasket Overhaul Kit (obviously)
New Exhaust Gaskets
Get Injectors Serviced
Belts (timing and accessories)
Water Pump
Thermostat
Idler Pulleys (mine looked good, but 1 kinda makes sound when you spin it.. how do you know if its still good?)
Alternator
Cam Seals
New MAF(?) (I did the whole 'unscrew the plug' thing and F-ed it up!)
Oil and Filter
Coolant
Spark Plugs
Plug Wires
Cap/Rotor
Input?
New Exhaust Gaskets
Water Pump
Thermostat
Alternator
Cam Seals
Oil and Filter
Coolant
Spark Plugs
Plug Wires
Cap/Rotor
Input?
#88
Don't mean to hijack your thread, but make 100% sure that you either repair your MAF correctly, or if it is too f$#@&^ up, replace it with a junk yard replacement.
I did exactly the same thing you did, and when I saw that it wasn't the way to disconnect the plug just closed it back up.
Three weeks later when I was trying to start my rebuilt motor, no spark.
It took me a week of trouble shooting before I stumbled back to the MAF.
The main clue was the check engine light not coming on when I turned the key on.
I had broken a couple of the very fine wires inside the MAF, and they were shorting out.
My $50 junk yard replacement got me running again, and I was able to fix my original and use it as a spare.
Good luck to you,
I was in the same boat last year as you are now, and I just took it one step at a time.
A hint is to make every task, even the most trivial, an individual project. Then when it is accomplished, celebrate the victory, and move on to the next task.
Art.
Good luck to you,
Art.
#89
Head Gasket Overhaul Kit (obviously) GET THEM FROM TOYOTA!
New Exhaust Gaskets
Water Pump
Thermostat
Idler Pulleys (mine looked good, but 1 kinda makes sound when you spin it.. how do you know if its still good?) Definitely replace them both
Alternator You can send original to Boyle Future Tech for double output
Cam Seals
New MAF(?) (I did the whole 'unscrew the plug' thing and F-ed it up!) It's a VAFM, not a MAF
Oil and Filter
Coolant
Spark Plugs www.sparkplugs.com
Plug Wires www.sparkplugs.com
Cap/Rotor www.sparkplugs.com
Input?
New Exhaust Gaskets
Water Pump
Thermostat
Cam Seals
Oil and Filter
Coolant
Input?
#91
So much misinformation...so little time...
Sure do don't it!
Valves pre-adjusted and ready to install? Not possible. They HAVE to already be installed to be adjusted. And also NO, the machine shop will not very likely adjust them for you after installing them either. Unless you request it be done upfront. They too know how much of a PITA it is, and will need to be paid for the parts and labor required to do so.
#92
Thanks MudHippy. I think my post was a bit vague though. I do not want to replace my cams but rather, I was simply wondering if the machine shop needs to have them along with the heads in order to do a valve job. As mentioned, I have never had a shop clean and/or rebuild my heads before, I am trying to get an understanding for what to expect and what is reasonable to ask them to do to heads with 174K miles on them.
Thanks again, any info is much appreciated.
#94
I asked a local muffler shop and they said it would be a royal pain to get rid of that crossover pipe.. Looks like I'll be taking it somewhere else..
#95
Little update. Got a call from the machine shop saying that 4 of the exhaust valves and 2 of the intake valves wouldnt seal properly. Said that it would just be best to get a valve grind (I believe thats what he called it..). Grrrrr! More money!
#96
i did note that there was such a thing as a "valve grind" set available from toyota but i'm not sure what it is.....i think i even posted it here on this thread maybe.
#97
hi redyota91. I did this last year on my 95 4runner and going to doing againg on my 91. I got my kit from rockauto.com. It was the cheapest place to get the kit. now I would ask the machine shop how much they would charger you to rebuilt the heads.
#98
So I went to my local Toyota dealership (Burien Toyota) and got a few things priced out. Thought this was a good starting point to compare things to. As I was walking out, the parts manager said that I might wanna try the website and order the parts from there as I could save some money. I could then pick them up at the dealership with no extra cost.. Odd. ANYWAY.. The printed prices are obviously from going through the parts department, my hand-written numbers are off of their site.
As you can see, its almost $500 cheaper going through their site than the parts department. So, the next step.. Which of these parts can I go through Napa/Schucks/Etc and get even cheaper?
Last edited by RedYota91; 10-20-2010 at 06:32 PM. Reason: Had to protect my online identity, yo!
#100
those hand-written prices seem to be in line with the best prices I've found.
napaonline.com....sells AISIN water pump / oil pump....under the name Altrom which I've found to be the same......sould be wrong, but my searching says Altrom and Aisin are the same
rockauto.com
toyotapartsales.com (is the trdparts4u OEM parts site)
toyotapartszone.com for great pictures of parts with #'s...it what i use to start my searches
