1990 4runner SAS
Old Feb 21, 2013 | 01:36 PM
4runnerJC's Avatar
Originally Posted by Sm0klnjoe
Good looking 4runner. I would think keeping the axles similar would be your best best. Then matching gear ratios wouldn't be all that difficult.
Yea, come to find out the front is a 4.09 and the rear is a 4.10 set-up.
Old Feb 21, 2013 | 02:44 PM
4runnerJC's Avatar
Done already
Old Feb 22, 2013 | 03:26 AM
Yota Fab's Avatar
Wheels
Will ifs aluminum wheels work on a Straight axle with a spacer? like a yota pre-86 frnt end,
Old Apr 30, 2013 | 11:33 PM
4runnerJC's Avatar
Most Wanted
My son was a little mad when he found out his front and rear diffs were geared differently (4.10 front and 4.56 rear). He just paid $459 for a front drive shaft and before we installed it we did the tire rotation/drive shaft rotation trick). According to the trucks Vin # and axle code I thought we had a 4.10 rear, but it has 4.56s which isn't bad but now we need to do the front gears. So back to the point, my don was pissed and pit his truck on Craigslist for $5500 and pretty much instantly we had three guys wanting it, even a guy over seas that didn't even care to see it before he sent $$$. My son decided to keep it and just save up for the front gears. I can't believe how bad people want these SAS crawlers. They are bad ass, don't get me wrong but I was surprised how easily he could have made a good bit of money off it.
Old Apr 30, 2013 | 11:36 PM
  #25
4runnerJC's Avatar
Looking good, just need those front end gears
Old May 1, 2013 | 04:12 AM
  #26
91 4Runner's Avatar
Personally I would look for a 2 set of 4:88 from a 92 to 95 from a pick and pull (door code G144)... It would probably be cheaper than regearing the front. Just my $0.02
Old May 1, 2013 | 06:50 AM
  #27
dropzone's Avatar
Fossilized
Toy gear won't fit a Dana 44.
When you guys put it on Craigslist did you mention the mismatched gear sets?
Personally I have never considered the rotate the d/s as accurate. On a loose dirt surface does the t/c bind
in 4wd?
Old May 1, 2013 | 02:05 PM
  #28
4runnerJC's Avatar
Haven't tried it. The front drive line spun 20.5 rotations per 10 rotations of the wheel x that by 2 and we got 4.10 or 4.09 which is what is inside for sure, then we spin the rear wheel 10 times and got 22.75 rotations on the shaft x that by 2 and you get 4.56s. I didn't want to try it on the dirt because that's way to far apart, the rear would be out running the front.
Old May 1, 2013 | 02:06 PM
  #29
4runnerJC's Avatar
Also we did mention on Craigslist the mismatch.
Old May 1, 2013 | 02:23 PM
  #30
snobdds's Avatar
Your overseas buyer was a scam...I suspect all interested buyers were though email...?
Old May 1, 2013 | 02:30 PM
  #31
B-Fake's Avatar
Having to regear one diff is no reason to get rid of a rig like that, It looks really nice. You can pick up a new ring and pinion for a couple hundred bucks, letting that truck go is something your boy will be kicking himself over later.
Old May 1, 2013 | 03:02 PM
  #32
Toyota~Boy's Avatar
If u are in dirt you can check it for sure. My 94 has 4.88 rear and 4.10 front. I have accasionaly used my 4wd. If u keep it in dirt or spinning your not gonna break anything.
Doing this you can check to be positive. If your ratios don't match it will not come out of 4wd unless you back up a bit while shoving the transfer case shifter.
I have a 4.88 front. I'm just to lazy to go out it in.
Old May 1, 2013 | 04:39 PM
  #33
4runnerJC's Avatar
This is safe? I just want anything binding or breaking. Not saying I don't trust your recommendation but can someone chime in and second this? I'm new to this so no offense, like said I just don't want to risk breaking anything.
Old May 1, 2013 | 04:44 PM
  #34
4runnerJC's Avatar
Just one, the others were local either by phone or text. Why do you have such a negative out look snobdds??? Most of your responses I've come across are sarcastic ha ha.
Old May 1, 2013 | 04:46 PM
  #35
4runnerJC's Avatar
Thanks for the comps. Yeah I'm glad he decided to keep it. It is unlike anything else you see on a daily basis.
Old May 1, 2013 | 04:53 PM
  #36
Swimmerboy2112's Avatar
I have to agree with the overseas caller most likely being a scam. And I don't think snobdds is being overly sarcastic, I just think he, like me, has seen many people get screwed over, so if he can help someone, he will, though he may come off as sarcastic.
Old May 1, 2013 | 05:38 PM
  #37
snobdds's Avatar
Have we met?
Old May 1, 2013 | 06:30 PM
  #38
Toyota~Boy's Avatar
That's just Snobdds.
You know Snobdds kinda like SNOB......
Lmao please know offense taken by my post.
Old May 1, 2013 | 08:59 PM
  #39
4runnerJC's Avatar
Have we met?
Hahahahahhaaha, no man I've just come across some of your comments on other posts, it's all good.
Old May 1, 2013 | 09:02 PM
  #40
4runnerJC's Avatar
I ran into one of those "my kid died in a drunk driving accident and we are selling this because it brings us such grief" scams. People are pretty F'd up.
MMA_Alex
25
Apr 18, 2017 05:07 AM
crashburnoveride
Aug 28, 2015 09:20 PM
madxman21
Jul 9, 2015 10:26 AM
karbin
Jul 5, 2015 11:37 PM
ptb12
Jul 5, 2015 01:49 PM
