1990 4runner injectors- compatibility q
Will the injectors from a tundra 2002 2uz-fe work in a 90 3vze?
I say no, but figured I'd ask. thanks, yall. |
Originally Posted by BritKnee
(Post 52405397)
... I say no, ...
Toyota says "no." https://parts.lakelandtoyota.com/p/T...32090F010.html |
Meaning "I'm thinking no", smart ass.
I couldn't find any info, figured I'd ask yall if you knew anything. Thanks for the link. |
(Post 52405479)
... smart ass....
Sometimes people try things even though Toyota says they don't fit, and find out that they do. (Or find out why they don't.) Maybe you read something and can provide a link to a blog. Other than that, it was hard for me to figure why anyone would even ask if a such a critical part (and one that doesn't cost much) from an 8-cylinder engine would fit a 6-cylinder from 12 years earlier. |
I am curious as to why you want to know..... :think:
I am pretty sure the Tundra (2UZ-FE) injectors will not work. The bodies of the injectors are pretty different, just looking by pictures of both injectors, and probably output different amounts of fuel for the same on-time duration. You probably will not find much information on this because most people just install the 3VZ-E fuel injectors because that is what the engine is designed to use. I guess if no one here knows, and you are dying to find out, your engine could be the guinea pig. :D :safari: |
