1988 toyota pickup 22re 2wd solid axle swap
right now my truck is sitting on a 1991 3L htp 4x4 rear axle. i am going to do one of 2 things for this swap, either keep that rear axle on and put a 1985 4runner sfa if the gear ratio's match up. or, put put a landcruiser front and back axles.
that brings me to my first question.: what is the gear ratio of a 1991 3L htp 4x4 rear axle compared to a 1985 4runner front axle?
and my second question: can i do the sas with a landcruiser axle? if so what year does it have to be? and will the rear axle fit?
Id go with the 85 runner axle and link the front and Chevy 63's in back use jeep wagoners front coil springs and spring bucket. Weld to ur frame and build ur own high steer and ull be wheeling in no time.
I'd suggest doing some searching further before progressing. Most of the info you seek is readily available with some searching and reading.
http://home.4x4wire.com/erik/diffs/
:wabbit2:
:wabbit2:
6th Gear
19
12-10-2019 07:31 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
