1987 4Runner SR5 5spd - It begins.
#41
85GT^^ is correct.... The "Gas gauge" issues usually seem to be a rotted out or just simply stuck up/misread, etc. HOWEVER, I've read lots of these complaints, where it says, "It's on 'FULL' for 80 miles, then starts to drop and I get maybe 100 from the rest of the tank, til on empty.... then it goes for 50 miles on empty".... And while reading lots of these complaints, I don't remember reading much on "DROPS OFF", as in 'LITERALLY' drops off and then maybe picks back up, like a short. So you NEVER can tell, 100%... it MIGHT be the gauge.... It would depend on how much fuel is actually IN the tank. Is it COMPLETELY full and STILL dropping off intermittently? Sounds more like the gauge if so... But if if it's reading full for a long while... then suddenly dropping off, NOT coming back up or reading 'FULL' when it's actually empty..... well, like 85GT said... "Probably time to pull that unit".
85GT.... I have an 87 4Runner, and while the Fuel PUMP is accessible under the back seat/pass. side.... I don't think the fuel level sending unit is so much.
For some reason, too..... the Sending unit seems to become FAR MORE inundated with RUST FROM HELL! Maybe because it's closer to a WALL of the tank? NO CLUE.... I just know it breaks/sticks quite often, EZ.... sorry to say. BTW, LOOK AT TERRYS_87 's build thread(OK, yes, which one? lol....HMmmm, I think it's the 87 build he's doing... He is RIGHT NOW dealing with a totally corroded sending unit/pump assembly/tank is filthy............ he's cleaned out these tanks like 6913 times! haha. He would be like "The Great Oz" on this one hahahaha..."All the answers, just in time!" lol.....
Best wishes, EZ.... and also... I slathered a nice thin bead of dielectric grease across the tape wires of all the cluster connectors... it seemed to really help with the intermittent Temp Gauge Fluctuation on the cluster itself.
PS> Do you happen to have an old Temp Gauge laying around? Maybe even a Harbor Freight near by with a 7$ one? haha... Hook it up to that sensor on the intake and VOILA... you know if it's the sensor or cluster gauge(or maybe wiring therein between, right?)
#42
I'm trying to find the sensor so I can clean it... can someone help me identify the sensor? I know its somewhere on the intake but the picture in the fsm is just not all that clear... Do you see it in the below pictures? Never pulled one of these out before so I'm just not 100% sure what I'm doing, but I know it's not complicated once I identify it.
#53
#54
No. Went and snapped one off mine. It's the orange colored doohicky down there...
For context, here's a little further "up" It's between the "EFI" throttle body intake and the valve cover/head. It's obviously closer to the valve cover/head.
#55
NOPE, .... that's the "Thermo-Temp-Time-Switch",....that piece IS on the lower intake, but it's on top of the Thermostat housing, right? NOPE< that's not it.... Look again at the pics I posted... See the LOWER intake? that's it... You CAN reach down in there and make sure it's connected well... Maybe clean it up even... Then look at the end of the connector, see if it's all corroded in there and maybe if it needs a good pinching tighter(CAREFUL, it is old and many hot cycles later for that plastic... it CAN be brittle, but most likely would be ok with a lil pinching down on the connector so it will grab the sending unit connection better, ya know?) The sending unit that I posted/was speaking of, it's not visible with your Plenum(Upper intake) on... You have to look down in the middle with a light and get a good look, k?
#59
Thanks for the pictures, they were very helpful. So....
I think this is the spot that it should be. And from what I can see, there's nothing hooked up to it, or the sensor itself is just plain missing?
Am I crazy?
Am I crazy?
#60
It's tough to see in the picture because I've lost most daylight, but it looks like a bolt with a small tab of metal sticking up out of the top. That tab has a small hole through it, as if you were supposed to thread a wire through it or something, but there is nothing in it...
I'll take better pictures in daylight tomorrow, but I think that's it and there's nothing hooked up to it, which I suppose would explain why my gauge is not working!
