17" Rims on my 92 runner?
Found a good deal locally on 17" wheels and tires from an 04' runner for $640.00..aluminum 5-spoke style...6 lug..265/70/R17 Cooper A/T's w/2K mi.
anyone know if they would fit my 92'?...running 15x7 and 31's now.. |
It depends on the back spacing.Bolt one on the front and see if it fits.My guess is it will fit perfectly.
hmmm..thanks..so I don't need any lift then..I thought I might need to lift it..
They fit on my '94 pickup:
http://img2.putfile.com/thumb/6/15915064835.jpg It was a LITTLE loaded! They are pretty tight & if you were to do any real off roading you'd have issues with tight turns, but under normal driving I don't have any problems. |
Post pics on here when you get them... I have wondered what those wheels would look like on a 2nd gen
Edit: TNRabbit... those look niiice |
looks good TNR...thanks for the info..
price reduced to $599 on the tire/wheel package...worth it? guy seems anxious to get rid of...might take $500.00...their off of a 2004 4Runner.
id say do it. make sure they fit right before u hand him the money, but do it. id check one up front and one in the rear just to make sure they fit right.
Not worth it, get some 24"
They are the same offset as the older Taco/4runner style wheels, 1" spacer would put them close to stock offset. 500 is what the tires cost alone, is it wort it to you? edit: tire height is the same |
I'm not sure what your saying Mudd...yes tires alone worth $500 so the rims are for free then..not worth it? 24" on my 2nd gen with no lift?
