1" Body Lift Not Enough for 33" MT-R's?
I have an '87 Runner and am still rubbing in the inner fender with articulation.
It has the following:
285/70R17 MT-R's (33" equiv) on wheels have stock back spacing + 1/4" spacers
1.5" BJ spacers
Rancho 24mm t-bars at the stock setting
4crawler 1" body lift
Pinch welds are rolled back
Is the simple fix to go with a 2" body lift? Problem is I might be running into extending brake lines, fuel filler, shift lever, etc. and the simplicity of the 1" body lift goes away. I read on the 4crawler site and here that I should be fine with a 1" body lift but front tires still touch. Whats left? Crank up t-bars a little?
Any suggestions would be appreciated.
1.5" BJ spacers
i suppose it depends on where you're rubbing.
my '88 has 33x10.5s. you appear to have 33x11.5s. the backspacing and 1/4" spacers may not be enough.
i have 4crawler's 1" lift, and 1.5" BJ spacers, and i've hammered the hell out of my pinch welds. (more than just "rolled back") and i removed the front lower spoiler. (well, it removed itself really)
my backspacing on the 8" rims is 4". i have cranked my t-bars up SOME, to get a more level ride height with the new rear springs.
it sounds to me like you're close, just need to 'fine tune' it. a little more t-bar lift, and lot more BFH.
Ugh. I felt like a pretty big gently rolling back those pinch welds. I hate it when the neighbors see me with the mini-sledge to "fix" my stuff . I'll take another look and also check and see whats on the inside of those fender well areas. T-bars can go up a little too I'm sure without a harsh ride.
Bob - I noticed alot of rubbing on my truck this weekend too yet your truck appears to be taller than mine.
I have a 33x12.5 tire, 1" Body lift, 1.5" BJ spacers with some crank to the t-bars, aftermarket rims with 4.25" backspacing - I beat the crap out of pinch weld but I think I'm going to have do more "custom work" with the BFH before Sundays run out in Florence.
Some additional crank to the t-bars should put you in a position where the up-travel is limited to a point where it won't be able to rub - but then you might need to do something in the rear to level it out. just my 2cents.
BFH is a precision instrument when applied by trained personnel. don't let the neighbors sway you otherwise!
if your still rubbing on the pinch, do what i did and cut it off with a grinder. i have a 95 p/u. i got a 4crawler 2in BL, bj spacers and a 2in AAL. 8in wide wheels with 3.75 BS. i wheel with 35 12.50s with 0 rubbing. and on the note about the 2in BL you mentioned, the only thing i extended was shifters, and radiator drop brackets
Heh - God bless the BFH!
Oh yeah. I installed the Nissan frontier mini-leaf pack from Deaver in place of the overload leaf for more flex and it gave me about 2" extra lift in the back so leveling isn't an issue :-)
A couple of questions
What led you to the wheel spacers?
What led you to the 24mm t bars?
What is your actual wheel backspace? because "stock" can mean a bunch of different things with OEM wheels.
T bars at stock setting. How did you measure that?
I have a bunch of ideas but they could all be wrong until we know how you got to where you are now.
Mike
Mike
^yes, I agree. You need to figure out exactly where they're rubbing - like a location in the wheel well where it makes contact. A pic will help here.
If you've already pounded the pinch weld, have bj spacers, 1" body lift - then something doesn't sound right to me. Stock backspacing for a stock 15" wheel is 4.75", but since you have 17s it could be related to that, but that's what well help figure out.
I made my 33/12.5s fit after some tweaking since I have no body lift on my 93 truck. Had it at nearly stock height after bj spacers(w/ relaxed tbars) and ended up having to go back to ~1.5-2" lift (stock tbar settings + bj spacers) to get them to barely not rub at full compression/turning. Since I have 15x8 wheels with 3.5-3.75" backspacing, it sticks the tires out more than before and caused some good rubbing at the new profile/turning radius; My rubbing was at the outside of the wheel well/pinch weld, so I was a bit more aggressive with my pinch weld and took a cutoff wheel and a 10lb sledge hammer to the area. Now, my only fitment issue is the rear, which apparently rubs on the rear panel at full stuff with weight in back - need to clip the corner or get longer shackles.
So anyways, you just need to play with the settings. I'm guessing a little bit of tbar adjustment will help. You don't need to "lift" it, just need to put a few cranks to up the preload on them so they don't compress so easily.
I've been thinking about these very questions:
The rubbing is on the lowest spot where the pinch weld is...nice and shiny.
Another piece of info that matters is I just installed low profile bump stops before this last outing so I am getting more than an inch of add'l travel up front.
Hmmmm....looks like the spacers are going to come off first because my back spacing is now 4.5". Cranking up the t-bars a little is easy too. I have the actual FSM book and will do a home alignment out of there afterwards. I'll see how that goes and work the pinch welds after that.
Thanks fellas.
What led you to the wheel spacers? I installed dynamic balancers on the wheels (love them btw) and put them on to create a little more margin btwn the calipers and the balancers. I forgot about those until I wrote the original post.
What led you to the 24mm t bars? I have a tube bumper and a big fat winch (not wench) hanging off the front.
What is your actual wheel backspace? because "stock" can mean a bunch of different things with OEM wheels. Back spacing is 4.75"
T bars at stock setting. How did you measure that? "Stock" was probably a poor choice of words. I matched amount of threads showing before the swap. Replaced UCA & LCA bushings and ball joints all around too so I had it aligned immediately following.
Mike
Mike
Thanks fellas.
33 x 12.50's on mine on 4.75 backspaced wheels and a 1 or so inch crank in the t-bars. Pounded pinchwelds no body lift. 87 runner same as 87 pickup.
Originally Posted by tj884rdlx
this makes me think hammering-to-taste is all you'd need.
You might be rubbing because of the ball joint spacers giving you the extra travel. Can't really say how far, I just beat the hell outta em till they submitted lol. I don't have BJ spacers, I would leave yours in. Cranking my t-bars had very adverse affects on my down travel.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
