YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Where do I find an E-Brake extension (https://www.yotatech.com/forums/f115/where-do-i-find-e-brake-extension-130356/)
Bskey Nov 20, 2007 06:26 PM
I lifted my truck about 4.5inches. Now the e-brake is really tight. Where do I find an extension for this or does anyone have any other ideas?
Thanks!
leiniesred Nov 28, 2007 10:48 AM
tight e-brake cable
Step 1 is to remove the cable from the last bracket extending back benind the gas tank, then step 2 is to cut or unbolt the band that holds the cable against the frame rail next to the gas tank. That'll let things drop down a bunch.
Next, depending on where the cable crosses your springs, you might want to extend the center pivot up, and simply cut off/remove the cable guide or extend it. then, extend your e-brake levers on the brakes to get it to line up nicely. with the center pivot.
After this, you cut all the e-brake stuff off and throw a log in the back for a wheel chock. (or look into t-case mounted brakes or linelocks)
4Crawler Nov 28, 2007 08:14 PM
Make one, I used a piece of water pipe and a longer bolt:
http://www.4crawler.com/4x4/CheapTri...III/Raxle3.jpg
http://www.4crawler.com/4x4/4R_suspe...III.shtml#Rear
Also, for no cost, you can just relocate or remove some of the clamps holding the e-brake cable to the frame. I think on mine, I removed the last one, lowered one or two in front of that:
http://www.4crawler.com/4x4/CheapTri.../GasTank_1.jpg
I have ~4-5" lift plus have the crossmember where the e-brake attaches raised 3" higher than stock and the e-brake still works fine:
http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
Bskey Nov 29, 2007 04:00 PM
That's a great jumping off point. I don't think I'll need to extend it, now that I consider the brackets. I'll be swapping on an IFS rear axle soon anyway, so I might just wait until I do that as I need to change the e-brake cable anyway.
