What is this box thing?
I don't know what to call this part. It bolts up under the intake, and then wraps around to the exhaust manifold. Will it hurt the performance of the motor to remove it?
hmmmm you related to this guy? :D
Originally Posted by 92civeg
(Post 51656390)
i orderd a weber today hope that solves it,im going to pull the intake to clean up that leaking plate and reseal it and im wanting to block off as much as possible, im wondering what is the box right above the starter that has a larger hose comming off it? can it be blocked off?do i need any cooling lines running to the bottom of the intake??
Awesome. Its gettin "deleted" soon. It just gets in the way.
LCE has the block plates for the exhaust side.
Awesome. I will have to look into that. Thanks
