Weber problems
I have an 85 pickup 4X4 with a Weber carb. I'm getting fuel to carb but not in carb . Will only run when I pour had in the car. Can someone help me an d. Not sure what model Weber this is or how to tell
You sure you have your fuel lines hooked up correctly?
Also, not that it matters for this problem really, but the model of your weber is usually on the side, I think its on the side closest to the firewall, I could be mistaken.
Originally Posted by dumpster84
(Post 52319597)
Originally Posted by Robbie82
(Post 52319616)
OK now do you know anything of the problem im having
Check your fuel lines and ensure they are routed correctly. It sounds like you might have them mixed up a bit. IF they are correct, verify that your pump is working. Other than that, I don't see what else it could be. When you say you "are getting fuel to the carb, but not in the carb" where is it going? I don't see how that is possible. Is your carb super dirty and clogged up? |
| All times are GMT -8. The time now is 05:32 AM. |
