YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   transfercase full of "slime" (https://www.yotatech.com/forums/f115/transfercase-full-slime-240100/)
LGs_Woody Aug 22, 2011 02:38 PM
i had slop in my transmission and transfer case shifters, so i put in the marlin crawler poly bushings. but when i changed out the transfer case bushing i noticed my transfer case was full of "slime." how do i go about flushing it out??
vital22re Aug 22, 2011 03:21 PM
drain and fill several times
LGs_Woody Aug 22, 2011 03:26 PM
should i lock it in 4 for a little bit after each time i fill it to knock some of the sludge loose?
xxxtreme22r Aug 22, 2011 03:27 PM
drain, fill drive a few hundred miles and do it again and again till it clears up. Photo? Almost sounds like you got water in the case, which means it's only gonna happen again.
LGs_Woody Aug 22, 2011 03:39 PM
I dont have a camera right now. but when i stuck my finger in it, it was literally like slime. but i just recently bought the truck and have been realizing how much the previous owner "abused" the truck. It dont leak any oil so the only place i can imagine water is getting in is around the "cover" where the shift lever goes in. any other ideas?
