Towing Boat with 85 PU?
Hello All,
I saw several threads on towing with the 85 Yota PU, but none specific on performance related to boating. I am planning on towing about 2000lb (boat, motor, and trailer) < 5 miles to and from boat ramp, unloading, and loading boat. Does anyone have any experience doing this? Should I expect things to work out OK as long as I am not planning on highway speeds or long hauls? Thanks, Dave 85 PU, short bed, 2wd, 4 speed, stock. |
ull be fine
x2 you will be fine.
yeah x3 you will pull no prob.
the owner that had it b4 me pulled a boat 1800-2200 no prob occasionally..pm for any other info :) g/l |
awesome. thanks everyone for the replies.
this is what I was pulling with a carbed 86 http://i86.photobucket.com/albums/k8...0/DSC02536.jpg
I don't know how heavy it was but it pulled fine my rear pinion seal was pretty bad and had a little leak after pulling that boat a few times I need to get another third member mine has developed a click and light clunk on take off. but not only was I pulling the boat around the same time but I was mudding and wheeling at a local spot so both could have contributed to the third starting to fail. where I live it is hilly I had to shift into 2nd on most hills but it pulled fine I am also in need of new brake pads soon that boat pushed me down most hills and my pads wore much faster then usual. |
Originally Posted by CyMoN
(Post 50895218)
