Straight axle noises
Old Jul 29, 2022 | 06:41 PM
reen's Avatar
Hey everyone,
So I rebuilt the knuckles on my 85 pickup and took it for a drive. Drove it on the freeway and city streets. 20 mins in when making a slight right turn a loud wind-up sound came from the front end with a loud pop. I pulled over and didn't see anything out of the ordinary. I'm worried continuing to drive it will ruin the axle. The wind-up sound was like when kids would put a playing card in the spokes of their bicycle then a loud pop. It is fine until another slight right turn. The front passenger side wheel is harder to rotate than the driver's side. I'm wondering if anyone can advise on what I should check out first. I realllly don't want to open everything back up if I don't have to. Any ideas on what could possibly be going on?
Thank you!!
Old Jul 31, 2022 | 03:16 PM
Damion812's Avatar
5 Year Member
A quick thing to check out is see if one of the hubs is engaged.
Old Jul 31, 2022 | 03:48 PM
dropzone's Avatar
Fossilized
Bearing preload etc was set up correctly?
greased the birfs?
Old Jul 31, 2022 | 06:13 PM
reen's Avatar
Thanks for the responses guys. They are automatic hubs so I don't think one side is engaged (I haven't been able to find much info on how they work). No one seems to believe that it has auto hubs, but it does. I pulled both apart a found the plastic ring, that covers the torx bolts, was cracked on the passenger side. It is hard to believe something that small made the noise that it did while driving it so I'm not too sure it was that.
I couldn't test the preload because the tie rod (?) would NOT come off with all the hammering I did. Sorry, I don't know all the suspension part names yet. I put the shims back exactly how they were. I definitely greased everything up. There was drag on the passenger side when turning the wheel, so I loosened the spindle nut a bit. I'm going to drive it again tomorrow and see if it happens again.
Old Aug 2, 2022 | 02:18 PM
Damion812's Avatar
5 Year Member
First thing I think of is someone put later hubs on (autolocking) and they don't fit. There is a difference between early axle hubs and the later axle hubs. I could be wrong though.
Old Aug 2, 2022 | 03:09 PM
dropzone's Avatar
Fossilized
pretty sure the spline count is different.
however that wouldn’t stop someone from installing auto hub outers
you need to make sure the preload is set correctly or you are gonna toast your bearings etc
Roger Brown has an awesome write up at 4crawler.com
Old Aug 2, 2022 | 03:56 PM
reen's Avatar
It's an 85 SR5 so I guess there was a limited amount that were made with auto hubs and sunroofs. I drove it and it didn't make that crazy noise so I think I tighten the locking hub nut too tight on the passenger side. Will do on the preload. Thank you all for your advice! I really appreciate it.
TCpickup86
May 19, 2021 11:36 AM
MP's4R
Feb 8, 2011 04:08 PM
brianrbhutch
Apr 13, 2009 02:20 PM
fdeeznutz
Jan 18, 2009 05:27 AM
kthrich
Aug 31, 2004 07:26 PM
