SR5 cluster 22RE- Where can i find one?
Ebay has one for $130 and there are no local junk yards. You guys know of any aftermarket clusters or where I can find an SR5 cluster for cheaper?
thanks.
thanks.
I just picked up a 87 4runner with a nice sr5 gauge cluster but with shipping i will not be much cheaper. I usually sell them for about 110.00 plus shipping. Pm me if you want one from a known source but if you want to keep looking for acheaper one that's cool as well. Where are you loacated shipping might not be bad.
there are no aftermarket as far as i know..best try at junkyards really so kinda out of luck
try car-part.com or posting ads on forums like marlin crawler i know for instance has a big norcal community, pirate, etc..
On here, eBay or the yard are your best options, BUT for some reason at the yard here which is just a yota yard the 22re was hard to get they had a couple but were cracked or terribly sun rotted. This is some wonderful reading when you find one
https://www.yotatech.com/forums/f116...w-pics-179106/
And 100 plus is about as good as you will get unless you find a yard that doesn't know the going rate
thanks guys, i guess ebay will to do.
mightymouse, i am in 32225 so if you can get it to me cheaper or include the oil sending unit ( i believe that is the only other thing needed) than let me know.
Yes the sending unit is all you need unless you need to do the tach wire, the thread I linked has everything you will ever need to do it and you can also get a sending unit from your local auto parts store.
unless you guys know that it can't be done, i am going to research using the intellitronix 6 universal digital cluster.
i don't see anything about a check engine light or "4 wheel drive", but the rest looks promising.
anything that'll work for a 22RE manual, my rig is an 85 4runner. I am researching going with the intellitronix digital cluster, but if the price were right I may go the "tried and true" route.
upullit, craigslist, and ebay are the only 3 places i can think of finding one. i found mine in a local upullit. i changed out my oil pressure sensor but my fuel gauge and coolant temp gauges are not reading right at all.
sojourner567
07-16-2015 08:52 PM
88yodabasket
07-13-2015 01:32 PM
