sr5 cluster?
ok i know if i really search i can find this but i need to find the post on installing a manual sr5 cluster in an automatic truck. i put mine in then noticed it didnt work, then i realized my truck was an auto to begin with(swaped auto for 5spd). so what do i need to change to make it work. i remember seeing this like a few days ago.
You need an oil pressure sensor that meant for a gage. The one on your truck is meant for an idiot light.
Search |
i already have the sender, yeah i know i need to search i was just feeling lazy when i posted this.
https://www.yotatech.com/forums/f123/new-gauges-installed-110383/
That was the post i put up like a week or so ago, i just completed this swap in my 84, auto gauges to a manual truck. It should pretty much be opposite if you are going to put a manual cluster into an auto however, your truck might be a little bit different than mine, depending what options you have, year difference, etc, but this is somewhere to start, i can try to answer any questions you might have Adam |
