Rears up Front
How hard is it to put rears from a 4runner up front on my 85 pickup? What is involved?
Originally Posted by corvettelvr73
(Post 50527853)
Everything you need to know. |
Here's how I did mine, probably one of the first rear->front swaps done in the US:
- http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front If you have crossover steering, it is not too hard. |
Bolting springs in isn't on my list of hard jobs.
Moving the steering boxing and going to a cross over steering set up is a bit harder. |
Well its out of my things to do for me. I will just buy a lift kit.
Why spend the money?
IT's cheaper to do rears up front and chevys out back. Even with a lift kit you have to weld in the mount of the steering box (IFS box) and most kits come with longer rear springs which means welding mounts in for those too. |
Wel I'm getting just a 3.5 inch lift that bolts right on and dont need any fabbing.
Most bolt on lifts aren't worth a damn.
What company? |
Either Ruff Country or Tuff Country i'm looking for more looks that how it will flex. I only do mild off-roading
Both companies are crap but if you just want looks then by all means go for either.
Sounds good to me.
Lol you wont flex worth a damn... I had a friend say to me "why are you building a rockcrawler if you dont like rock crawling". My answer to him was that it was the right way.
Your gonna build a mall crawler. |
(Post 50528675)
Sounds good to me.
If you don't have big bucks to spend then lift kit springs are definately the way to go. It becomes very time and money consuming to put rears on your stock SA rig. |
Rear up front question?
Could you bolt stock 87 rear springs up front on an 83 without adding any leafs, or having to extend your drive shaft?
Originally Posted by Slowly but surely
(Post 52251310)
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml or you could re-drill your spring perches and plates to move the axle back about 1.5" if so desired. |
Okay cool thanks! So if I got the 2" spacer I should be right on?
Probably best to measure your current drive shaft length now and then measure after installing the springs and see how much it changed. Be sure to check both compressed and extended lengths before and after since that will all change with the different springs.
Quick check on compressed length is to drive the passenger front up on a ramp, extended is easy, use a jack to lift the front tires off the ground. |
Originally Posted by 4Crawler
(Post 52251315)
You can probably get those spring hanger pins from Toyota or from some on-line shop or grab a set at a junkyard. Other option is to get some metal (like a thick flat washer) that fits inside the big hole, drill out the inside to fit your new bolt (likely 18mm) and then weld that washer into the hole and grind the wed smooth.
Or hack off the original hangers (they are prone to cracking on the early trucks anyway) and fab up a new hanger: - http://www.4crawler.com/4x4/CheapTri...ringHangerDrop Or you can purchase a front hanger from any shop that sells solid axle swap kits. |
Guess I got some decisions to make. Thank you very much
