YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   randomly dies? (https://www.yotatech.com/forums/f115/randomly-dies-167629/)
sr5yota84 Feb 21, 2009 08:42 AM
randomly dies?
i have got an 84 pick up sa with the 22r. I just rebuilt carb. I wil be driving while its on choke then when it kicks off choke and i push in clutch it dies. Then its a PITA to start again.. And then it will usually do it one more time then it will be good. Any ideas?
algranger Feb 21, 2009 08:48 AM
I dont think you can be driving while it's on choke.. when you touch the throttle the choke should disengage
sr5yota84 Feb 21, 2009 08:53 AM
ok while its on high idle. and then it will kick down to normal idle(if it doesnt die) around 180 degrees
algranger Feb 21, 2009 08:57 AM
Oh i see, i didnt realize it was still cold in that case it could be staying on choke
Where is your idle speed set for when your off the fast idle?
sr5yota84 Feb 21, 2009 09:00 AM
about 1100rpms... It seems like the truck is loosing vaccum or somthing. I can keep the truck running and it seems to runn better but it wont idle at that point. Then I rev it to about 4000rpms and it does fine..?
algranger Feb 21, 2009 09:10 AM
Are you saying you rev it to 4k and it idles fine after that?
sr5yota84 Feb 21, 2009 02:31 PM
Yes. I will rev it up around 4000 rpms and it seems to do fine after words.. There are times as well that i turn it off and start it up like 5 min later and it wont idle.. I have no idea whats causing it. I was thinkin accelerator pump or egr valve but i dont know..
84toylover Feb 22, 2009 09:16 AM
I was having a similer problem with my 84 22r. It would be fine while cold then say after turning off and starting again it would run really bad and die like it was running on 3cyl. Turns out I had a bad cap, maybe cracked, would get water in there I think just condensation but changed that and no problem now. Also had riched up the mixture because of emissions problems.
These are just some suggestions, I think sometimes we immediatly think "carb problem" but often it's an ignition problem.
Good luck!
sr5yota84 Feb 22, 2009 11:16 AM
Good luck!
Yea i have a new cap and rotor.. I am starting to think coil issues or there is somthing in my float bowl clogging. IDK yet hmmm its getting worse tho!
84toylover Feb 23, 2009 10:57 AM
By the way you have the same tire combo I had for years and wheeled the p!$$ out of it just the way it was. I wish I still had those tires!
sr5yota84 Feb 24, 2009 06:45 AM
Yea they are great tires.. The only issue i have is they pack with mud/snow really easy..
Alaskan Yota Feb 24, 2009 04:07 PM
I was having this issue on my 82 recently, it got progressively worse the more often I would drive. If the truck sat for a few days it would run great but after driving for 4 days it was doing just as you described. I rebuilt my carb and put a new intake manifold gasket on and it has driven 60 trouble free miles today... tomorrow or the next day i'll find out if it's really fixed. I also threw some new plugs into her and put on all new vacuum lines.
When was the last time you did a carb rebuild? If it's been 20K miles or more i'd look into it.
I'll post in a few days and tell ya if it fixed the problem.
Niko
