YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Problem with headlights (https://www.yotatech.com/forums/f115/problem-headlights-98255/)
myyota Oct 28, 2006 11:21 PM
My headlights only work on high, when turned to low i get nothing, is there a headlight relay somewere that can go bad and cause this problem ?, if there is a relay were is it located ?, or any other ideas what the problem might be.
Elton Oct 28, 2006 11:25 PM
check the bulbs ? never mined i guess you have sealed ones
Firefightertaco Oct 29, 2006 07:50 AM
i would check the bulbs first cause head lights are dual filament one for high and one for low, your low beams might be burnt out
herpestes Oct 29, 2006 10:46 AM
check the fuse / relay box on the inner fender well
4Crawler Oct 29, 2006 05:45 PM
Likely the headlight switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
