Power Steering Parts
Ladies and Germs, please tell me what parts I need (complete), to install power steering. This manual stuff is killing me. Also please tell me what cars I can pilfer parts from as well as what other years' trucks. I have an '89 base truck with, of course, the famous 22RE. One last stupid question: If I get a turbo (Jegs.com has one for 800 and some change), instead of an intercooler, could I get by with methanol injection? Thankx!!
Because I just went through this myself, you're going to need the power steering pump, brackets, reservoir, high pressure hose, low pressure return (barbed fitting on steering box) fluid feed line (3/4? Rubber hose), fluid cooler(a foot or two of hard line that circles in front of the radiator and back) power steering box (good time to upgrade to hi-steer)
Older Toyota Celicas had 22r motors in them and I would assume the pumps/brackets would be the same but don't quote me, and probably any Toyota pickup/ runner with a 22r you can get the entire setup from As far as turbo, you can probably run without an intercooler and be just fine, because without some sort of aftermarket tuning your not gonna have the fuel/timing to make it above a few psi |
