YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   need help with CPU Code reader (https://www.yotatech.com/forums/f115/need-help-cpu-code-reader-106015/)
Badkitty Feb 2, 2007 10:50 AM
I have a 85' 4x4 22RE ,Im borrowing my friends code reader
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
i dont know where the plug in on the truck is. i dont have the owner manual but i do have a haynes auto manual in PDF, but there is no search function. can someone tell me where its at?
Elton Feb 2, 2007 10:52 AM
its by the fuse box cant miss it
Elton Feb 2, 2007 10:55 AM
if that dont work http://www.off-road.com/toyota/tech/codes/index.html
Badkitty Feb 2, 2007 05:15 PM
uh...i dont see any kind of plug on or anywhere near the fusebox under the dash. i looked at box under hood and dont see anywhere to plug in either. anyone with same year take a pic of its location or what it looks like
also i just noticed...i have a 22RE....should my ECU say 22RE on it ? cause it only says 22R
toyota_mdt_tech Feb 2, 2007 09:29 PM
On ther 1985, it will be a yellow 2 pin plug near the air cleaner. Jump the 2 pins together. There is two plugs, other is a 4 pin. Both kinda park in rubber cups on the inner fender next to the air cleaner. Jump the 2 pin, read the blinks of the check engine light.
Badkitty Feb 2, 2007 10:28 PM
ok i tried that but nothing happened. i guess what i figured is true. dealer i bought ttruck from disconnected engine light. either that or light is out, but i doubt that. is there no plug to connect that code reader into then ?
toyota_mdt_tech Feb 3, 2007 08:58 AM
Are you using the round plug or the "T" shaped one? The "T" one only powers up the fuel pump. You should of ran the round one.
4Crawler Feb 3, 2007 10:01 AM
See:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
The one circled in light blue:
http://www.4crawler.com/4x4/CheapTri.../FuelPump1.jpg
I got my code reader at Office Depot:
http://www.4crawler.com/4x4/CheapTri...CodeReader.jpg
Badkitty Feb 3, 2007 12:07 PM
are they plugged into anything ? or those rubber sockets just to hold them? cause mine were just laying around dangling.
4Crawler Feb 3, 2007 12:09 PM
Rubber sockets are just there to hold them, one usually has a rubber cap and the fuel pump test jumper just hangs loose. They are diagnostic plugs, only needed when doing troubleshooting. I hard wired some of mine to switches for ease of use:
http://www.4crawler.com/4x4/CheapTri.../FuelPump3.jpg
toyota_mdt_tech Feb 3, 2007 12:25 PM
They are usually just hanging around when someone checks the air filter, knocks it our of the rubber socket. The rubber socket just keeps them tidy looking. The other member posted a perfect picture of the sockets. The large yellow 4 pin one is used to set VF learned, great to know if you ever have to calibrate a air flow meter, but of no concern to you as of yet.
Badkitty Feb 3, 2007 05:12 PM
ok so i pulled my gauge cluster out to check bulbs..all bulbs fine...all fuses fine both inside and in engine compartment. My check engine light never turns on. even when key turned to ON and/or IGN . nor does it blink or anythign when i jump that connector to diagnose. did you see what i asked about the ECU only having 22R written on it
4Crawler Feb 4, 2007 11:50 AM
Yep, they all have 22R on the ECU boxes. Maybe the ECU is bad of the CEL light is not coming on, or maybe the wires between the check connector and ECU are bad, check for continuity at the ECU connector.
