YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Looking for a clutch (https://www.yotatech.com/forums/f115/looking-clutch-183097/)
kcpanages May 28, 2009 08:11 AM
I need some help. i have a 85 yota 22r manual with 9" suspinion with 15/38.5x16 boggers. Im running 5.29 gears with full spool piece front and rear. im new to the yota but been mudding with a chevy for over 10yrs. just kinda clue less on what to get. i found this http://www.trail-gear.com/clutch.html Are they any good? also i have looked at the center force. just kinda clueless. any help would be great full.
Kris
oldgold3vze May 28, 2009 10:30 AM
I'd just put a new OEM clutch in it. I'm running a similar setup to you, 40s, 5.29, spools, etc, and I have had good luck with stock clutches. Plus, they're cheap.
TOYOTA 1 May 28, 2009 10:37 AM
check this one out http://www.marlincrawler.com/clutch/...ch-kit-1200-lb i love it!
drew303 May 28, 2009 11:04 AM
Originally Posted by TOYOTA 1 (Post 51149711)
I have the marlin clutch too. It's worked well for me over the years. I recently had it off (motor out) and there was only minimal heat brazing on the pressure plate and flywheel after 3 yrs of abuse, bout 40k miles about.
kcpanages May 28, 2009 07:45 PM
well i believe ill spend the extra few bucks and get a Marlin.......... Thanks yall
slabcrawler May 29, 2009 07:02 AM
You might also consider a LUK clutch. They sell them as a kit with TO bearing, PP and disk with alignment tool. Search online for the best price. It's called a LUK Pro Gold. Bottom line is the Marlin one is great, Luk great stock Toyota great. Just get the cheapest one.
PS don't forget to surface your flywheel.
