YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   interchangeable 3rds (https://www.yotatech.com/forums/f115/interchangeable-3rds-74073/)
88yotatruck Dec 15, 2005 04:23 AM
Will an early(79-95) solid axle 8" 3rd fit the rear of a 98 4runner? Are all 8" thirds the same regardless of year and whether they came out of the front or back ?
westy44runner Dec 15, 2005 05:55 AM
yes it will fit the 4runner, as long as that 98 4runner did not have an e-locker third.
The non e-locked tacomas had 8.4 diffs
4Rocker Dec 15, 2005 07:40 AM
Right on. E-locked axles have a slightly different opening, but a regular 8" third will fit just fine. Just be sure to check the gearing. Most stock early 3rds are 4.10 because of the manual trans; I THINK most of the 3rd gen 4Runners are auto and have 4.30s.
ATLRoach Dec 21, 2005 05:35 AM
There are two types of rear 3rds they are named 4cyl and V6. They V6 have thicker ring gears and larger bearings, this is the one you want.
Also E-Locker rear ends use V6/Turbo Gears and there is no such a thing as a 8.4" Toyota Rear end. The supposed "8.4" runs a 8" ring gear.
FilthyRich Dec 21, 2005 05:52 AM
some are 3.90s Most are 4.10s and the ones with e-lockers are 4.30s
