YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Ignition Control Module gone bad (https://www.yotatech.com/forums/f115/ignition-control-module-gone-bad-316222/)
Hoopster1978 Oct 15, 2022 12:15 PM
1985 22re with bad ignitor, searched, at a loss for a fix, replacement. Any suggestions, sources. At a loss on what will work.
Baller Oct 20, 2022 12:36 PM
What makes you think it's the ignitor that's bad?
Time for a trip to a local pick and pull?
Melrose 4r Oct 20, 2022 06:16 PM
Some people have retrofitted GM ignition modules. They are cheap. I read it on Ih8mud.com maybe.
osv Oct 22, 2022 11:20 AM
the ex53 module? https://www.rockauto.com/en/moreinfo...89341&jsn=1106 fits '85-'88 22re
it's been out of stock for a long time, at all vendors, i put in a stock notification at rockauto and managed to nab one for $114, which was a good price... it seems to work fine, but the wiring is smaller diameter, which is disappointing; i tore the original unit apart to see what was inside, it's totally not serviceable.
worst case is that there are a lot of listings at the junkyards... see the bottom of this thread for cross-referenced part numbers: https://www.yotatech.com/forums/f116...-motor-305381/
when this ex53 ignitor fails, the engine will not start, you are dead in the water, so carrying a backup is probably a good idea.
