how many degrees to run timing at
i have a 1984 toyota truck and i just converted to a double row timing chain and i had my timing set at 5 degrees and i was wondering what people run theres at because it runs better when its more advanced than 5 degrees so if anyone could tell me what they run theres at if there not smogging it any time soon thanks Nick
upgrades:
toyota stage one race cam downey offroad header flowmaster exhaust system K&N air filter With all of these performance upgrades I run mine at 8 degrees on 91 octane fuel. It has plenty of power with this set up. |
Also it passes smog with this set up
HI there!
Hey newbiemuela! I noticed you live in Walnut Creek.. I'm just down the highway from you in Vacaville. Anyway, the double row chain kit should in no way conflict with the original timing specs for 1984 22R (which I believe is set at 8 degrees below top dead center.
Now if you choose to advance it even more, that's all fine and dandy so long as it doesn't ping. After that you're destroying your piston tops. AND you will fail a smog inspection. Aside from the fact that it will change the CO ratings on the sniff test, they do actually check the timing and will notice it is not set to factory specification. Stupid California... only thing its good for are the young girls. :hillbill: |
