YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   help on performance problem (https://www.yotatech.com/forums/f115/help-performance-problem-296376/)
stevehotwirered Aug 18, 2016 12:32 PM
I have a "92" 4Runner with a 3.0 liter 5speed tranny with 220,000 miles on it,replaced head gaskets on it and it has no compression on #1 and#6 cylinders at low idle,but does not burn any oil and will still run down the road at 80+ mph and has an audible miss at idle. have replaced all plugs, wires,cap and coil.any ideas on what i need to do to correct it?
osv Aug 19, 2016 09:53 AM
that's not logical, how exactly can you tell that there isn't any compression, only at idle?
did you check the valve lash?
stevehotwirered Aug 21, 2016 05:47 PM
did compression test after installing head gaskets and had no compression on #1 & 6cylinders
stevehotwirered Aug 21, 2016 05:52 PM
coil wire pulled,and had wife crank it over and had compression on all cylinders except 1 & 6
thefishguy77 Aug 26, 2016 11:35 AM
autocorrect fail
Did you do the head gaskets yourself? Have you checked the valves? Are you sure you had a good seal l for the compression test on 1&6?
wyoming9 Aug 26, 2016 12:01 PM
Did you put coolant in the engine ??
Pressure test ?/
Why did you replace the head Gaskets ??
Did it get Hot ?/
Check for cracks in the head ??
Just what numbers did you get ??
No compression failed head gasket !!!
Bad valves got the valves between 1 and 6 mixed up
Cracked heads
Rings gone
Cam lobes wiped !!
