HEI for the 22r and 22rec
ok guys, does anyone know of an HEI system that can go into the 22r and/or the 22rec? i have 2 22r's and 1 22rec, between the 2 trucks i have. both trucks are 85's. one of the engines in out of a 93 and was a 22rec and got converted to a 22r. i like the carbs better than the inj. want to go to the Weber 34/34 on everything.
but back to the point, is there an HEI system for the 22r and 22rec engines? thanks for your help and info. |
and here is a thread with guys using 22r dist. on Motorcycles to get HEI..
http://xs650temp.proboards.com/index...nt&thread=7899 |
and I'll take all your EFI stuff off your hands...
Trade you for all my fancy carbed stuff! including offy intake! |
just use the one off a 22r. all it takes is a hot wire
thanks for all the help guys. i'm going to try the 22r way first and then see where this leads me. i have a spare one laying around. i'll post and let you know how it goes.
EFI for Carb
Originally Posted by Outsane
(Post 51133511)
is it a standard carb or the 34/34 weber set-up that i want to change to?
If I were carb'd, I'd probably look at a CDI system first. If that didn't work, I'd stick with stock.
After all, what do you mean by HEI? |
High-Energy Ignition system (HEI). These HEI systems fire a considerably "hotter" (increased voltage) and "fatter" (higher amperage) spark across the spark plug electrodes.
on 22rs i doubt youll see much differnece. thats for big block vhevies and fords. performnce engines. and a performnce engine 22r/22re is not.
Uh... HEI pretty much came standard on a lot of cars by the mid-80's and was by no means limited by engine size and performance. Granted I have not looked to see if these are points or not, but they're probably fine. There won't be a power difference, but perhaps a smoother-running engine and a PINCH of fuel mileage.
There were threads floating around on using the HEI from a mid 80's Chevy straight 6. THose engines were crap, they made the intake and head a one piece mold in those days. |
