YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Header question (https://www.yotatech.com/forums/f115/header-question-256626/)
bcumbie Jul 25, 2012 06:51 PM
Header question
Will a header labeled to fit a 90-95 pickup or 4runner 4wd with 22re fit my 84 pickup?
250000_yota Jul 25, 2012 06:59 PM
I don't believe so. They changed the design of the cylinder head in 85(?) and I'm not sure if that changed the exhaust manifold design or not.
bcumbie Jul 25, 2012 07:17 PM
Ok, next question...will a 22RE Valve cover fit a 22R head? My reason for this question is, my 84 had a 22RE sticker on the valve.
bcumbie Jul 25, 2012 07:43 PM
According to LC Engineering, they sell a smog-less "off road use only" header that will fit all 81-95 20r/22r/22re motors.
http://www.lceperformance.com/mobile/default.aspx#P926
So does that mean it should work? A header labeled for a 90-95 pickup? I'm not concerned with smog equipment. And don't mind modifying or blocking off ports etc.
