YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   head unit install questions (https://www.yotatech.com/forums/f115/head-unit-install-questions-122121/)
yotafeind Aug 10, 2007 09:26 AM
i am trying to install my deck but i cant seem to find the memory wire or the power wire that come out of the dash. does anyone know the color of these wires or have a good picture of them? it would be greatly appreciated. thanks
OSU4Runner Aug 10, 2007 09:48 AM
Did you purchase a harness to hook up your head unit to the truck harness? That should make it a painless install
yotafeind Aug 10, 2007 10:35 AM
no there is no factory harness. someone cut the wires. it was like that when i got the truck so i have to find everything first and then hook it up.
4Crawler Aug 10, 2007 10:46 AM
Run your own wires is the best answer. I did that on my '85, adding a fuse block at the battery and use a decicated power and ground wire back for radios, CBs, etc. Keeps the power (and sound) nice and clean. Otherwise, you can pull switched power off of the back of the cig. lighter and constant power off of the dome light circuit or similar.
Embfixer Aug 10, 2007 11:08 AM
I had a problem like this once. I went to the dealer and asked for a copy of the wireing manuel. They photo copied it for me and I was on my way..tl
OSU4Runner Aug 10, 2007 11:33 AM
Go to this website, enter your vehicle info and will give you wiring info
www.the12volt.com
darth brian Aug 10, 2007 08:33 PM
yellow is memory and red is power when i wired up my head unit
