| 4Crawler |
Sep 17, 2006 05:33 PM |
Just make sure to shift out of 4WD while moving straight ahead and while on a loose surface, like dirt or gravel. What you are feeling is normal driveline binding caused when the front and rear axles/tires travel a different length, like while turning. You may also have slightly different size tires front and rear that can make the binding worse. I try to shift out of 4WD before leaving the trail, on a flat stretch of road and just let off the gas a little (neither accelerating nor engine braking), while holding a light forward pressure on the t-case stick. It should pop out easily, no need to force it. If you try to shift out after a turn, try reversing the direction of the turn while shifting. That is if you made a sharp left before shifting, try either making a right turn (forward) or left turn (in reverse) to unload the driveline before shifting.
