YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   floor (https://www.yotatech.com/forums/f115/floor-129331/)
84yota4x4 Nov 8, 2007 07:06 PM
floor
i was thinking of doing a roll on bedliner for the interior. any ideas? rhino liner? or evre heard of grizzly grip?
CJM Nov 8, 2007 07:08 PM
herculiner..
navyredneck Nov 8, 2007 08:35 PM
durabak, look at my thread. kind of expensive but I wanted it red
stormin94 Nov 8, 2007 11:35 PM
Hell yeah!!! Rhino line the inside, I like the idea......
85toy Nov 9, 2007 09:51 AM
i prefer line x
84yota4x4 Nov 9, 2007 01:54 PM
thanks..i looked at the durabak and im leaning towards that. does it hold up good?
navyredneck Nov 9, 2007 03:20 PM
Mine is holding up really good and the smell was almost like new car smell :hillbill:
One or two edges have peeled because I didn't sand aggressive enough.
A patch under my clutch has dissolved due to leaking clutch which was unnoticed until after the floor was done :bang:
One gallon will be enough for a regular cab with two coats with enough left to do a tailgate (I did a test on my tailgate which had very little sanding and just a coat of xylene prior to -> it's held up really well considering I drag steel trash cans across it)
I'd recommend the durabak if you want to use a colored bedliner.
84yota4x4 Nov 9, 2007 03:29 PM
i was thinking a grey not sure yet..did you primer before? or just sand
rowdy235 Nov 9, 2007 05:19 PM
my friend coated the inside of his cab with duplicolor bedliner. Its holding up OK only had it in for around 3 mos so time will tell. We just sanded it like heck and then wiped it down with some acetone.
84yota4x4 Nov 9, 2007 05:53 PM
cool that doesnt sound too bad.
