YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Engine Noise at Startup (https://www.yotatech.com/forums/f115/engine-noise-startup-185473/)
85RunnerSR5 Jun 28, 2009 07:25 PM
I recently had my 22RE rebuilt about a month ago and I have only put about 60 miles on it. When I go to crank it after it has sit overnight, it makes some type of noise for less than 5 seconds and then it clears up. It's not a knock or a rattle. It doesn't sound like a broken chain guide. It is the early style 22R. It's an 85 model 4Runner but it was manufactured in late 84. I was wondering if it could be the rocker arms needing to be adjusted (I know they need to be readjusted after break-in). Other than that, it fires right up, runs great, purrs like a kitten, and runs strong on the road. It just has a weird noise at startup. If you have any ideas, let me know!
toyota4x4907 Jun 28, 2009 07:33 PM
Well you told us what it DOESN'T sound like......what DOES it sound like?
Plumbrbob Jun 28, 2009 07:52 PM
its your thingamajioger LOL
is it a whine or a squel or a moo, meow, rattle, or chatter?????
TOYOTA 1 Jun 28, 2009 07:57 PM
^^ lol hahah
85RunnerSR5 Jun 28, 2009 08:27 PM
It sounds like a weird (clack clack clack) noise and only lasts a few seconds. It's hard to describe. If I had a video camera with audio I'd upload it and let you listen to it.
Listen, don't make fun of me ok? I just asked a bad question and didn't give all the details. I don't know everything there is to know about Toyota's (I'm not trying to have an attitude by any means).
Like I said before, it runs great at idle and driving down the road. It doesn't make any other noises except that.
toyota4x4907 Jun 29, 2009 04:33 AM
Hey, we were just giving you a hard time. In a nice way.
The sound could be piston slap.
85RunnerSR5 Jun 29, 2009 08:12 AM
Hey man, it's all good
Do you think it could be because it hasn't broken in yet?
TOYOTA 1 Jun 29, 2009 08:44 AM
id say your not getting the correct amount of oil for the first few seconds. do you have a manual gage in there?
85RunnerSR5 Jun 29, 2009 04:07 PM
Yeah, it has a gauge, no idiot light.
TOYOTA 1 Jun 29, 2009 04:15 PM
ok. watch it during start up and see if there is a small delay from the time it starts to the time the gage starts reading.
85RunnerSR5 Jun 29, 2009 07:05 PM
ok, I'll take a gander at it in the morning when I go to crank it.
Plumbrbob Jun 29, 2009 07:10 PM
mine made a strange clack clack on startup sometimes too then after a 2hr highway drive my starter motor fell out LOL
85RunnerSR5 Jun 30, 2009 01:21 PM
The gauge has a delay when it cranks up.
jdw1 Jun 30, 2009 01:24 PM
if its in front of the engine chances are its the timing chain. the aftermarket timing chains arent as good as toyota. mine is doing the same thing. clatters at startup and goes away.
85RunnerSR5 Jun 30, 2009 01:35 PM
I don't think it's the chain, I know the noise you're talking about. This is different. My brother's pickup sounds like that when it starts up (of course it has 327,000 miles on it).
ephwang Jun 30, 2009 06:35 PM
Mine makes a noise at startup when cold. Its from the exhaust manifold not sealing to the head (due to studs pulling out). When the manifold warms up, it expands enough to seal the gap.
85RunnerSR5 Jun 30, 2009 07:02 PM
Thanks for your input guys, I really appreciate it. When I get some time I'm gonna start troubleshooting. Feel free to give me more ideas and I'll let you know if anything changes.
TOYOTA 1 Jul 1, 2009 08:51 AM
what kind of oil/ filter are you using?
85RunnerSR5 Jul 1, 2009 07:06 PM
It's a NAPA gold filter, I usually run a Toyota filter on it, but that's what the guys put on it at the machine shop. I haven't changed it for the first time yet, I've only put a little over 200 miles on it the past 2 days. I run 10W-30 Valvoline in it.
85RunnerSR5 Jul 11, 2009 08:30 PM
I've been doing some thinking. I just got done looking through my Haynes manual. The oil viscosity chart is saying that from around 40 degrees Farenheit and above that I should be running 10W-40, and below 40 degrees I should run 10W-30. I am currently running 10W-30 in it. Could that be part of the problem?
The temperature where I live here in North Carolina is in the high 80's to the low 90's for the most part of the summer. I was talking to one of my friends today and we got to talking about it and was wondering if the lighter weight oil could be what's causing this noise. If yall have any clues let me know! Thanks!
