Electric fuel pump?!
So I need a new fuel pump for my 84, and I just bought a electric pump. Was wondering the correct way to wire one up. Its got two wires (basics) one hot and one ground. How should I wire it the best with the least amount of headache. But also safest in trail/road use.
You remove the old pump from the tank and install the new one.
Just wire it to the fuel pump harness . That way all the safety features are intact . You don`t say if you have a EFI engine . If you bought a cheap pump you will be real good at changing them just be careful getting the lines off the fuel pump bracket being seized and rusty they like to break. |
