| deepmarsh |
May 14, 2015 11:42 AM |
Egr question
I have a 1985 4Runner. 22re 5speed. Complete rebuilt motor, new denso o2 sensor, new denso plugs, wires, cap, denso reman afm, adjusted tps, correct timing, new silicon vacuum hoses, so on and so on. I'd been having this strange miss and hesitation in 2nd gear at light throttle around 2100-2700 rpms. At full throttle it runs great. I put a piece of a coke can between the egr valve and the intake plenum and that got rid of the slight hesitation I had. There is still a little bit of popping in the exhaust but it's barely noticeable. Should I replace the egr valve or just leave it blocked off since this is obviously my rough running problem. Also are there any other components of the egr system that would need replacing or just the valve? I don't really understand all I know about the egr system.
