Confirm Correct 20R Head w/PS Bosses for my Hybrid Build
1 Attachment(s)
Just wanted to get confirmations that this is the correct 20R head to use in my '84 w/PS. The head also has a mechanical fuel-pump cut-out. Guy says it is a '76 head, but who knows. Jus as long as it will work. Plan on porting it for OS valves anyway.
Thanks... Nate |
Id try to help since i have the same setup but i cant make out the pic
If you click the pic it enlarges. The bosses are at the far left, front of the engine. They seem to look exactly like my 22R head bosses. Are they tapped? Who knows. Easy fix tho.
https://cimg6.ibsrv.net/gimg/www.yot...b8f3955384.jpg
Here is mine with the ps pump and bracket installed. Minus dist |
