Charging issue
So my truck when running puts out anywhere between 12.4 and 11.9 is the lowest I've seen so far. I had a bad starter and flat charged battery in her for a while idk if that'd kill the alternator Orr not. But I have tried running lights and it doesn't seem the bring the overall voltage of the battery down at all after a lap around the block. Any advice would be appreciated. Loose belt? Bad ground? I have work for the next three days so I have no time to work on her. But a list of what to check once I get time off work would help.
Originally Posted by PAgrown
(Post 52171837)
I suppose you measured those 12.4 and 11.9V with volt-meter? At which point? Healthy charging system should have 13.5-15.1 Volts at "B" post of alternator. See charging system explained on my Sig. There are suggested places to take voltage measurement, without taking things apart. Best of luck. |
Also could be worn out alternator contacts.
I tested at the battery terminals. I'm gonna check the grounds on Sunday when I've got work off. If the alternator is really hot is that a good sign it's going bad?
Btw what are alternator contacts?
(Post 52172259)
(Post 52172260)
| All times are GMT -8. The time now is 05:36 AM. |
