Charged power steering pump now truck won't start
Changed power steering pump now won't start!! checked spark plugs distributor (since you have to remove it to change the p.s. pump) what else should i check?
Take a deep breath and go take a break, then go look at it again and see what you didn't get connected back right. Get that ground back on? All the plug wires to the distributor? Pull the other end loose by chance? It is something simple you are overlooking.
ok slept on it
plug wires reattached to dist. in the right order...... check
plug wires to spark plugs..... check
ground wire reattached..... check
did i ground out the coil prim.res. .5 ohms/ sec.res. 12.8 ohms (no)... check
Why did you remove the distributor to replace the power steering pump ?, ive replaced a couple of power steering pumps on 22RE`s and have never had to remove the distributor.
voiddweller
19
05-02-2016 09:10 PM
yourrealdad
7
07-21-2015 08:53 AM
