85 sr5 runner starts and dies when warm.
just bought a 85 efi yota 4skinner and it runs good but dies after it warms up. any ideers?
check your maf sensor, it controls your fuel/air mixture, or Idle air control valve when its warm can you smell gas at all? If you can take off your intake and clean it with MAF cleaner.
i got her in the shop and found 60 psi (dry/ with oil) in one then 120 on 2-3-4 and 150 with oil in 2-3-4. it has milk oil (bad head gasket i belive) and im guessing its blown on one. i pulled the whole motor and put it on a stand. some one was in this motor recently im sure of it it has a brand new clutch with assembly greas and red greas on the bearing in the crank. (its late and been a long night and i cant think) they used silicone on EVERYTHING, intake, EXHAUST!!, timing cover, oil pan ect so i figure ill do a rear main oil pan timing cover and chain while i do the head gasket. i have a feeling the last person did the head and may have used silicone on the head gasket! well ill keep posted and take some pics of inside the motor!!
pulled haed... number 1 has dings like crazy in it. im gonna pull the pistons and probly re-build it.
I had the same exact problem. Previous owner said the fuel pump was new. Well I tried everything and it all came back to the fuel pump. I yanked it out and seen that his mech lied to him the fuel pump was old. I swapped it out and runs perfect.
Seen the rest yikes that sucks |
Put a new / used motor in it cause it had a bad HG. Doesn't do it now.... weird the motor I put in has a bad noise so I'm bummed on that. Gave the thing to my dad and he's in love. Lol I still gotta get him a motor
