85 4Runner with a Rough Country 3" suspension lift
Which consists of new front and rear springs, and new shocks.
.... I guess he's not "bone-stock" anymore! Before: http://i172.photobucket.com/albums/w...nner/BR_03.jpg After: http://i172.photobucket.com/albums/w...HAL_lift-1.jpg |
looks good! i have the same lift. but with some shackle lift and a body lift
niiiiice. hows the ride with them?
Originally Posted by yoder519
(Post 51376750)
Someone suggested that the stock shocks are crap and if I upgraded to nitro shocks it would make a difference. But that's not gonna happen right away... I am thinking that the springs might need half-a-year to mellow a little. My 87 has mellowed in the year after its SAS/lift..... |
take it offroad once and itll mellow out thats what i did with mine
Originally Posted by misterzee
(Post 51376807)
The ride is surprisingly stiffer. You really can't put your coffee cup down anymore. LOL
(Post 51377098)
thanks.so its pretty stif huh.. these factory SFA aint the smoothest ride anyways. reason i ask is i was gonna do the rough country 3in springs rear(since they mount in factory location), and stock RUF, or RUF and 63s. its still up in the air
I wonder what the effect of back-on-front is? |
looks good. You plan on keeping the same wheel/tire combo?
I'm thinking about buying the same kit, does anyone have more pictures of it installed?
heres mine with 33 on 15x10 wheels. putting 35 on with shackles and cutting fenders.https://www.yotatech.com/picture.php...pictureid=9957
nice, I have the 2nd Generation 4inch Rough Country Lift and it has held tough! The ride was definatly stiff at first but it only takes a few wheelin trips to smooth it out
I have an 85 Pick-up SR5, and I just got the Rough Country 3" kit and before I start tearing my truck apart, I was wondering if I needed to do anything with the stearing and/or the drivesafts. Any info will help.
The driveshafts you can leave alone, and I am almost 100% certain you don't have to do anything to adjust the steering. It will handle differently, and if you plan on adding on the the 3 inch lift later on, a hysteer system will be good.
84 4runner lift
i was looking to put the rough country 3 inch suspension lift on my 84 4runner will this kit work evem though it is for the 84 toyota pickup HEC 715H
Pickup and a 4Runner are not setup up identically in the rear end.
:wabbit2: |
What is different?
Originally Posted by waskillywabbit
(Post 51923687)
:wabbit2: |
hey misterzee...what size tires are you running on your rig?
Did any of use who did this lift to your 4 runner or pickup use the shims on the front axel?
