84 transmission swap help!!
hi i have a 1984 2wd toyota pickup. its got a carb'd 22r, stock 4sp auto tranny,everything stock. the tranny is starting to go and i figured now is the time to do the tranny swap i want to. i want to swap a five speed manual trans in. i now how to swap one into another kind of car(a 95 240sx) but will this be different? i know i need:
transmission new driveshaft flywheeel new shifter clutch master and slave cylinder clutch pedal new brake pedal(or just trim down the existing one) what else do i need? and will a w55, w58 transmission work? also i want to clean up the engine bay so how to i remove all the emission tubes? i want to switch to a weber 32/36 too. |
